To my knowledge RCA never made a "diamond" speaker.
The "original" RCA theremin speaker was the RCA-106 (http://www.radiolaguy.com/images/pre-1930/Theremin_106-1.jpg).
The RCA-106 is an open-back cabinet (http://www.radiolaguy.com/images/pre-1930/Radiola106-i.jpg) with only a dust cloth covering the back (http://www.radiolaguy.com/images/pre-1930/Radiola106-r.jpg). The bottom is wide open.
There are many audiophiles that prefer an open-baffle loudspeaker design - at least for the mid to high frequency drivers. The baffle is sized to the lowest frequency the driver is to produce. As you know, they require a driver with higher self-dampening qualities.
As coalport would certainly point out, a bottom end that is not fully supported can contribute to a more "human" vocal quality.
While the diamond speaker can be used as the sole means of sound projection, its main function is as a monitor for the thereminist (and dramatic prop). If you want earth-shaking bass...use a PA speaker or subwoofer.
