125 Theremin
Posted: 2/4/2010 6:39:26 PM
StonedImmaculate
I started working on Art Harrisons 125 Theremin the other day:
http://home.att.net/~theremin1/125/125.htm
SoFar (http://www.facebook.com/#!/photo.php?pid=238337&id=1787391681)
and I had a few questions I was hoping someone could answer...
Will any 1mH coil work or do the other values make a difference? I was thinking of winding my own with 199 turns on a 2.25" dia. by 4" long piece of PVC.
Would a volume control similar to this one work?
http://www.oldtemecula.com/theremin/opticalvolume.htm
And then, last but not least, I may get shot by a vintage radio collector for this one, but I pulled the amp out of an old emerson console and was wondering if I could use it...?
It uses 2 50eh5 tubes and a 12ax7 and it has a phono input and an input for an am/fm tuner. I was wondering if I could use one of the inputs & replace the 12ax7 with a 12au7 if needed, or if there was someplace I cold tie in a new input? I already paralleled the outputs into a single 8" speaker and that seems to work fairly well.
Schematic (http://www.facebook.com/#!/photo.php?pid=238338&id=1787391681&fbid=1125013624015)
Thanks,
Michael
Posted: 2/4/2010 6:41:14 PM
StonedImmaculate
Image links don't work, I will hopefully have some new ones in a little while,
Sorry about that,
Michael
Posted: 2/4/2010 6:46:59 PM
StonedImmaculate
And here the they are:
So Far (http://www.flickr.com/photos/47228773@N05/4331438072/in/photostream/)
Schematic (http://www.flickr.com/photos/47228773@N05/4331438350/)
Posted: 2/7/2010 6:53:52 PM
StonedImmaculate
Anyways, heres some more pictures of the construction...
The Amp (http://www.flickr.com/photos/47228773@N05/4339299320/)
New Chassis (http://www.flickr.com/photos/47228773@N05/4339298920/in/photostream/)
Posted: 2/7/2010 8:55:43 PM
teslatheremin
Perhaps your inquiries would be better suited on Lev Net.
Ask Rupert Capelle to ask Art Harrison.
Good Luck with that...
teslatheremin
Posted: 2/8/2010 1:45:43 AM
StonedImmaculate
Thank you
Posted: 2/8/2010 10:36:29 PM
Jeff S
Why not skip the middleman and contact Art directly?
theremin1@att.net
Posted: 2/9/2010 11:49:07 AM
StonedImmaculate
Thanks, that would be easier, however I think that I am going to wire it so that if the coils don't work, I can replace them with ones that will and just see if it works, If they work well, should I post the specs somewhere?
Posted: 2/10/2010 5:33:09 PM
don_pb
The old Emerson amp should work ok. It's not going to output much power ... maybe 5W per channel?
Try using the AM/FM input ... that should be line-level and would be suited to the theremin output. Don't change the 12AX7, though.
Don
Posted: 2/11/2010 8:44:18 AM
StonedImmaculate
Thanks, I was playing around with it today and found the phono input works great for guitar but I really need to get an isolation transformer before I play around with it too much, finished the amp but am still waiting for a mouser package which is driving me crazy, but oh well, should be in today. Here is a pic of the amp, sorry to keep posting pics, I just think it looks pretty snazzy...
TravelSmart Hi-Fi (http://www.flickr.com/photos/47228773@N05/4347959010/)
Thanks again,
Michael
