[i]"I cannot find an antenna model in ltspice, so I just put the 33p capacitor, as you did, in parallel to C10. Then I cut C5 and C1 as well as R8 and R4, following your schema.
What's wrong?? :-S" [/i]
You will not find an antenna model - there isnt really such a thing.. What is an antenna? In the case of a Theremin it is (for every practical purpose) only a capacitor... For real 'RF' there are a whole set of 'antenna' parameters you could specify - but there are special simulators costing many thousands $ for these sort of apps..
Don is right! What have you got.. 3 transistors, a couple of coils, diodes. Rs + Cs... What are you doing? You are building a virtual Theremin, debugging this - even when you get it working perfectly, you dont have a Theremin! ... Build it in hardware, debug it in hardware, and you will have a working Theremin.
I love simulations, and I think they are also a good way to experiment and get into electronics.. but I think that a beginner needs to play with both simulations and reality - flipping from one to the other - to get the best educationally from it.
Please feel free to email me your LT files (email is in my picture <---) and I will quickly look them over for you.. [b]But please check the obvious first! be sure all component values are correct (for example 10n not 10u !) [/b]- If it turns out to be a careless mistake, I will insist you make a $10 donation to www.streetkidsrescue.org! ;-)
But my main advice now ? Pick up your soldering iron!
[b]-- In reply to Don -- ""hardware doesn't lie" [/b]
Hi Don,
Alas, this is not always true! My use of simulations is mainly to overcome the problems related to putting a project into production.. Knocking up a "one off" rarely justifies simulation - I would never have run a simulation for something like the EPE 1995 design - one can more quickly mess about with values on a board and get a simple circuit to work.
It is the ability to run sweeps for component tolerances, to verify that nothing in a design is 'borderline' so one can safely go to production which makes simulation, in my opinion, vital.
Hardware can (and often does) lie .. something simple like the Hfe of the transistor you put in your prototype can make a circuit work - but this transistor may have an Hfe of say 300, when the devices have a range of 150 to 400.. A careful (good) designer is unlikely to make such a gross error - but it is easy to miss the obvious in a complex design.. When a lot of money (and reputation) rides on things working without problems, simulation is a good investment.
The other area I use simulation for is to quickly test new (often whacky) ideas.. And here it is a wonderful vehicle for exploration - one can create 'unreal' components and engage with a hypothetical world and build hypothetical devices.. Many of my best ideas have come by doing this - throw away the constraints - do something amazing - then find a way to achieve the same thing using 'real' components.
The biggest problem with simulation is just how fussy it is - it takes years to master SPICE setting so as to get the right balance between convergence and accuracy for a given evaluation - it becomes instinctive (Most of the time I can not explain why I tweek parameters I do, in order to get simulations to run).. And one really needs good knowledge (and expierience) of electronics so that one can instantly see when something doesnt look right, and is likely to be a lie.
Beginners get best results by learning basic electronics from simulations - A Theremin is well outside of beginner territory for simulations, IMHO!
[b] -- EDIT -->[/b]
[i]"after C14-R14 oscillates between 175mV and -175mV"[/i]
What do you get on the collector? is it the same sort of AMPLITUDE as on my simulation? - leave C14 and R14 out and just concentrate on getting a good amplitude on the collector..
