Hello everyone, I'm a high schooler who wants to build a simple, cheap theremin just for fun/to see what happens (no serious purpose, I just want to goof around). Anyway, I found the schematic for the theremin from "103 simple transistor projects" and got really excited that it was so simple and small. Then, while searching radioshack's website, I realized that all of the transistors and inductors are from the 60s and hard to obtain. I also came to the conclusion that there is nothing "simple" at all about it. So, I have a few questions:
1) Will homemade inductors work/how big should they be? Should they be made with "naked" or insulated wire?
2) Must the transistors be exact models, or will a generic radioshack PNP transistor work just fine?
3) Will 100pf variable capacitors wired in parallel with 100 pf fixed capacitors be equivalent to a 200pf variable capacitor?
4) how does one hook up an antenna? will stiff brass wire work?
Thanks for any advice, it is greatly appreciated.
