So far, we know for certain that the pitch oscillators work, the pitch tuner works, the detector works and the volume oscillator works. I'm uncertain about the volume tuner, and I'm not sure how to check this without a fully functional circuit.
The problems we are having are the following:
- The antennas. We know that our pitch antenna is not functioning properly. We aren't getting any changes in the variable pitch oscillator's frequency.
- The VCA & VCA processor are not working.
For the VCA/processor I think it will just be a matter of sitting down and checking all of the connections again.
But I am very concerned about the antennas. We should be seeing at least some change in the signal from the oscillators with the pitch antenna.
Right now, we have the inductors for the pitch antenna on a smaller breadboard, separate from the main part of the circuit, and we were using copper rod about the size of a coat hanger for an antenna. This breadboard is connected by a small lead to the variable oscillator on the main board.
I was hoping someone here could give me some advice or suggestions.
