I really don't think you can "burn out" an amp over time. If the output level is high enough to damage the circuit, it will do it right away.
The issue is that, unless you adjust your theremin output level to match the guitar amp, you can't turn up the volume on your amp very high and you lose some control range on your volume antenna.
Matching the output level to the amp that you are using will enable the full capacity of the amp. Then the only question is the quality of the amp.
