TOT: Some days you are the statue and some days you are the pidgin.
Posted: 11/7/2006 11:31:26 PM
buddycraigg
Is there a special off topic section I should be posting to that I haven’t found.
EDIT. i removed my rant. we all have bad days.
but since i have completely ruined this thread, i might as well do some testing to get use to how this forum works.
[img]http://pff.hostkansas.com/pffimages/DSC01291_1.JPG[/img]
[img]http://pff.hostkansas.com/pffimages/DSC01291_1.JPG[/img] (http://pff.hostkansas.com/pffimages/DSC01291_1.JPG)
[img]=http://pff.hostkansas.com/pffimages/DSC01291_1.JPG[/url][/img]
now let’s look at the real thing
[img]http://pff.hostkansas.com/pffimages/known_good01.jpg[/img]
testing the solenoid…
looking at the assembly like this
The upper two connections are for the vacuum sensor
and the lower two are to drive the solenoid.
[img]http://pff.hostkansas.com/pffimages/plug_connector.jpg[/img]
first I removed the short hose from the solenoid to the vacuum sensor
then pried the vacuum sensor and the connection block out of the bracket.
if you remove the solenoid from the bracket, be careful not to break off the fitting pointing sideways
[img]http://pff.hostkansas.com/pffimages/known_good02.jpg[/img]
removed two screws that hold the connection block and vacuum sensor together.
Now you can see what is left of a 20 year old foam filter.
[img]http://pff.hostkansas.com/pffimages/known_good03.jpg[/img]
I used a $3.00 meter from harbor freight for the testing, so any meter can do this…
Check the vacuum sensor without vacuum.
It should be an open circuit, or infinite resistance.
[img]http://pff.hostkansas.com/pffimages/known_good04.jpg[/img]
on the 3 sensors that I tested, they all showed continuity around 5” of mercury vacuum
[img]http://pff.hostkansas.com/pffimages/known_good05.jpg[/img]
then I tested for continuity in the windings of the solenoid.
** the readings were all over the place. From very high resistance to almost no resistance. This would back up pauls statement,
[QUOTE][b]Originally posted by Paul Prince:[/b]
I had a bad weather-pak pin (corroded) in the connector to the solenoid.......Paul[/QUOTE]
[img]http://pff.hostkansas.com/pffimages/known_good06.jpg[/img]
Posted: 11/9/2006 2:36:08 PM
DiggyDog
I was wondering the same thign this morning.
Maybe a non-theremin related ection woudl be fun.
Posted: 11/9/2006 6:12:49 PM
Maybe we could have The Off-Topic Thread.
Just somewhere to post occasional random stuff for no good reason.
(Gordon wanders off humming Alabama Song. Oh, don't ask why.)
Posted: 11/9/2006 9:12:23 PM
Jason
Ask, and ye shall receive!
The new Off Topic forum is here:
http://www.thereminworld.com/forum.asp?cmd=t&F=808
Enjoy, and keep it clean :)
Posted: 11/9/2006 10:31:50 PM
buddycraigg
thanks Jason,
being able to quote another user would be handy too
