I second the notion of ear training and muscle memory being the focus for control. It's almost as if hand/fingering technique is there to serve the pitches that you hear. It would be awesome if we could know how our brains worked and switch the order for a few of these many variables that influence our playing.
I set the pitch nob of my Etherwave standard so that the entire range is within arms length. This does make the intervals alot smaller. There are great benifits however. Here's the tradeoff: The closer the intervals, the easier the strech is between small and medium intervals if you choose to use aerial fingering techniques. Out of tune notes can easily and quickly be moved back in tune because they are literally millimeters away. The downside is that such minute movements require better than absolute stillness. I found that the only way to acheive this is to plant my body in a seat. If I stood with this this method of tuning, I would be wobbling so much that the pitch would shift up to 3 semitones. Then not only would I have to worry about hand technique, but also the additional movement of correcting hand position to counter the wobble.
It is crazy to think of how all these factors are so closely related, but then I guess that's why we love the thing.
Is it bad that I'm leaving my Etherwave switched on 24/7 ? I probably should have posted this question long ago. I just don't want to wait 10-15 minutes for the thing to stabilize before I can really dig in to playing the thing.
