[b]1.) Two ACTIVE "antennas"[/b]
The quotes around "antennas" scare me. What are you actually sensing? I'd be very uncomfortable buying an instrument that senses proximity using something like infrared, since all the infrared "theremins" have been very low end and cheap.
[b]QUESTION: A switch to swap sensors (left<-right)? or does pitch on the right / level on the left suit everyone ? (I will offer a left-handed version if anyone wants this - but is an extra switch a good idea, or would it be a bother?)[/b]
Any feature adds cost. You have to decide whether you want to raise the prices for everyone to accommodate it or lower your profits to accommodate it or make it a custom option that costs extra or make it a custom option that doesn't cost extra. If you don't mind doing the custom work, I would offer it as a custom option, but I'd definitely offer a lefty solution. We are offering a different lefty solution altogether, but nonetheless offering one.
[b]Anyone have any ideas about whether a 10ms (100 times a second) update might cause a problem?[/b]
Speaking as a computer programmer who often does user interface work, my experience is that people generally perceive anything that happens more than 3 times per second (every 333ms) as "constant". I think 10ms should be fine.
[b]Would YOU be more inclined to buy the TherAsynth if it had a real hetrodyning sound source than an analogue synthesised Theremin output?[/b]
Me? Not especially. But, I think the market would. My perception of theremin buyers is that they're mostly looking for that classic theremin sound, nothing complicated.
My group is planning to offer instruments that (simultaneously) output sound, control voltage, and MIDI (not certain on the MIDI yet but it's a strong possibility). We'll likely do the sound in a very basic way, on the basis that we're trying to produce a cheap instrument and our customers can buy something else (maybe from us) if they want different sound. Or they can use the CV output with an analog synth.
[b]The sensors outputs are voltages linearly proportional to distance. These voltages (and other signals) will be taken to an expander socket at the back of the instrument.[/b]
Keep in mind that if the voltages you output don't correspond to the input voltages of one or more of the major synth manufacturers, it'll be useless for controlling an external synth. We're planning to make our instruments' output compatible with Moog CV input.
[b]I feel that the market is utterly cluttered with "Theremins" which make noises, but are grim (or impossible) to play musically - Unless I can produce the most musically playable Theremin related instrument ever seen, I will be displeased with myself -
Having said that - There is a full analogue synthesiser in this instrument - so it will certainly be possible to produce "effects" ;)[/b]
I'm glad to hear your strong interest in playability. We also are most concerned with playability. Once we have a working prototype we plan to do whatever it takes to make it very linear before we consider moving on to a production design. I sincerely hope that we (you and I) will be bringing at least two very playable new models of theremin to market.
[b]I have another question for you all - I intend to house this unit in a high quality case.. But I also want to keep costs down -
