Microphone Stand for Mounting a Theremin
Posted: 2/18/2008 10:51:45 PM
therem13
Hi,
I've seen many microphone stands at online stores like amazon, but I don't know which one will give me the proper stability and height adjustment to use with my theremin. I'd like to have a tripod stand, and I'll put a mounting flange on the bottom of my theremin. I've looked through flanges as well, but I don't know how to tell which flange will fit with which stand.
Here are some products I've looked at:
Stand-Boom/dp/B0002E55UY/ref=pd_bbs_sr_1/002
-6749617-3176808?ie=UTF8&s=musical-instruments&qid
=1203392434&sr=8-1>
Craftsmanship-Compatibility/dp/B0002GY12A>
dp/B0002M2U2C/ref=pd_bbs_sr_3/002-6749617-3176808?ie=
UTF8&s=musical-instruments&qid=1203392434&sr=8-3>
-Flange-Female/dp/B0002ZPKEO/ref=sr_1_1/104-2905235-3452732?ie=
UTF8&s=electronics&qid=1203392536&sr=8-1>
Will I want a male or female mounting flange? I assume it depends on which type of stand I get, so could anyone suggest a good combo that will work well?
Thanks,
Dan
Posted: 2/18/2008 11:08:53 PM
vonbuck
most mounting flanges are female, and most mike stands are male. All standard mike stands are the same size. As long as the tri-pod stand is a mike stand, it's all standard.
Hope that helps
Andy
Posted: 2/18/2008 11:13:06 PM
therem13
Thanks Andy- I saw some flanges that had threads, and others that just had what looked to be an octagonal female socket (like the atlas one). Are mic stands usually threaded?
Posted: 2/19/2008 12:10:50 AM
vonbuck
yup
Posted: 2/19/2008 7:07:20 AM
Jeff S
The standard mike stand thread (in the USA anyway) is 5/8"-27.
The mike stand is a male thread and the microphone mount (flange or otherwise) is a female thread.
The flange you need is Atlas part number AD-11B (chrome) or AD-11BE (black).
The photograph on the Amazon website showing a hex (slip fitting) is incorrect. The description describes the piece as a 5/8"-27 female thread.
The male mounting flanges are for mounting a microphone to a table top or lectern, taking the place of a mike stand.
