Hmmm. When I earlier checked the voltage from pin 12 of the LM13700 to ground, it must have been during a stable period when no hiccups were present.
Because just now, it is hicupping badly. And when I tuned "L11" according to the manual, I can never get it stable to zero volts. The voltage reading from pin 12 is fluctuating randomly between -0.9XV to 1.1XV. edit: in fact the range of fluctuation is more - between 1 to 3V.
Before assuming L11 is bad, what other components should I check? I see a couple of caps around there plus some 3904 transistors, how do I check these?
