[i]Why would use of pitch-preview give a player a more solid hand/ear coordination and better ingrained muscle-memory than non PP practice?[/i]
With a pitch-preview, you can come in on the correct pitch which means that you open your phrase with a consistent arm and finger position. Thus, your interval (distance) to the second note of the phrase will be consistant.
If the first note is a little "off" there is limited time to correct it before moving to the next note. If the first note is a little off pitch, then you must squeeze or stretch the interval to the second note. The entire phrase can become a struggle to correct everything simply because the first note wasn't firmly planted.
Imagine, if you will, to play a scale or arpeggio on the piano. If the first note is the wrong note then you have to deviate to manage a good second note and complete the phrase -- more often than not the whole phrase falls apart. Play a good first note -- and even if you flub a passing tone the overall phrase will likely turn out ok.
To clarify (or muddle) my comments about intuition -- suffice to say that, to me, "intuition" is an amorphous, metaphysical concept. It may be nice to harness the power of intuition however for me to do so would be like an attempt to herd cats.
