Hi Teslatheremin,
I agree with everything you say here.. The properties of the wood used, and the cabinet dimensions etc could (would?) play a significant part in the modulations being fed back -
Parameters I can think of (in possible order of importance) are:
Coupling: The acoustic coupling of the antenna to the chassis is likely to have a significant effect - for example, coupling via a angular component (a right angle at the side of the Theremin, as in the Moog EW models) would probably generate more movement on the horizontal axis than an antenna mounted on the top of the Theremin.
Antenna: material, dimensions (thickness, length, construction[solid/tube etc]) and any other factors influencing its response / resonance/s to audio frequencies. I think these factors will even influence the tone quality in response to an external loudspeaker, but obviously to a far lesser extent than if coupled physically to the speaker via a chassis. Coupling via chassis to antenna could be significant if the Theremin has a large cabinet in close proximity to an external loudspeaker.. but with modern (small) Theremins I do not think there will be much coupling.
Cabinet: Its dimensions,construction, materials, resonances, and generally everything which relates in any way to the spectrum of audio frequencies that get to the antenna coupling point.
Speaker: The response charactaristics and its coupling to the chassis.
Probably, the best way to 'emulate' a RCA would be to copy the physical layout and materials used on the RCA as closely as possible (dimensions of cabinet,materials, type of wood, antenna/s etc) and to get a speaker and amplifier matching the charactaristics of the RCA as closely as possible ( The mass of the weighty electronics would also need to be taken into account.)
- then, into this, build a modern Theremin capable of replicating the waveform from the RCA. My original ideas on emulating the RCA were based purely on evaluating the waveforms from an RCA system (Theremin+original amplifier and speaker) and building a circuit capable of producing these waveforms (+ many others)..
I am now inclined to thinking that this would turn out a bit like a good electronic piano.. No matter how good the emulation was, you will never capture the full richness of an acoustic piano, 'simply' because one needs the large carefully tailored mass of the piano, Tonal qualities of the wood, and the sympathetic interactions of the tone board etc, and these cannot be crafted into electronics yet (I doubt they ever will be). I thought that, because the Theremin was a 'purely' electronic instrument, there was no comparison - there were no acoustic factors involved in the output waveform, so any Theremin could be 'easily' replicated if one had a sophisticated enough reconfigurable analogue computer..
I now think I was probably wrong.
A year ago I posted this: (http://www.thereminworld.com/forum.asp?cmd=p&T=3966&F=3&p=2)
>> [i]I believe the difference between a Clavinova's "emulation" of a Boesendorfer grand piano sound, versus a Theremin "emulating" another Theremin is huge.. I do not believe it is possible to COMPLETELY emulate an accoustic instrument electronically.. The mere physical aspects - resonances in the cabinet / toneboard etc, the locale of the output sounds and harmonics, the effect of the players non-obvious interaction with the mechanical components... Emulation is good - but it is not (and I think probably never can be) perfect.
However - I do believe it would be within the realms of possibility and even achievability to make a Theremin which created tones IDENTICAL to OTHER THEREMINS - simply because both are electronic instruments producing waveforms which can be analysed and duplicated, and the number of factors which define the tone (which are far simpler than what one gets from even the simplest acoustic instrument) can be broken down and rebuil
