I have now spent a day examining the E-Vox photos - I am not *sure* about anything really (even with these excellent high resolution photos, one cannot see tracks running under the IC's or be sure of connections running between the legs of the IC's).. but..
What I thought was range-switching circuitry is, I now believe, the wierdest 'mixer' I have ever seen! I do not believe this is a heterodyning Theremin at all - (I may be wrong!) - I think that the reference and variable oscillators independently act on Cmos switches in a way slightly similar to that used in the EW Pitch to Voltage converter (but at much higher frequency, therebye overcoming the F to V problems at low frequency) and that the front-end, which at first glance looks almost conventional, is a capacitance to voltage converter.
Range switching is achieved by simple summation of voltages which are added to the voltage from the front-end.
I have located what looks like two 'tone generator' blocks - These, I believe, consist of a VCO and a VCF each.. They are each identical and are built with a pair of LM13600 Dual OTA's - One looks like a VCO, the other looks like it is configured as a LPVCF.
Voltages (from the Front-end and from the MIDI-CV converter) appear to be routed to these tone generator blocks.
There is a circuit block that has a quad transistor array, and I suspect this is an exponential converter - but again, I am not sure - I have not been able to trace actual connections of voltage paths, just been able to see 'groupings' of traces from blocks which guide me in my hypotheses.
I have more questions almost, now that I have come this far, than I had when I started. Much of the circuitry is quite crude, the oscillators (which I have the most complete schematics of - almost certainly 95+% accurate) are simple single transistor designs, much less sophisticated than the standard EW oscillators - I do not believe that they, on their own, could give the stability that thev E-Vox is, I believe, renowned for... It MAY be that the nature of the 'mixer' behaves in a way where drift (which is likely to affect both variable and reference oscillators similarly) is cancelled out.
I believe that the good linearity is achieved by the unusual method of tuning the Theremin - Onlike most other designs I have seen, tuning is done on the variable oscillator. A variable capacitor sits across one winding on the Equalization coil (not directly on the tank) - On first seeing this, I thought there would be an adverse effect on linearization by doing this - but I now realize that, if the matching of the oscillator frequencies are carefully done (there are no variable inductors on this design, but there are 'pads' on the oscillator circuits on which 3 capacitors are placed in parallel - I suspect these are selected on test) and if the inductors are extremely high quality, then tuning in this way will simultaneously adjust frequency and linearity to compensate for background changes in capacitance.
At this time, I am both highly impressed and also quite unimpressed - This instrument had / has so much more potential than was realized.. A few jack sockets giving CV outputs would have extended it usage.. CV tracking the full audio range without the problems one gets from the EW+ at low frequency. I also do not understand why, after having made a good CV outputting Theremin, Moog reverted back to inferior technology for the EW Pitch-CV. I believed that my method of getting full-audio-range CV from a Theremin was unique and original (and it may yet be).. But Bob managed to do this by (I believe) a slightly different method, Years ahead of me! Why has this been hidden from the world? I feel this is so sad.
