On the topic of Modular Synthesizers - I just purchased one from Analogue Solutions. Or rather, two "MiniModulars" which I proceeded to make into a quad-oscillator, dual filter audio damage machine.
Rather than buying a signal processing machine, I would buy a "system" modular synth, which you can actually play regular notes on, for timbral and tonal variation. It's nice to "not" use the same timbre to process into a new sound.
Also, when getting into modular synthesis, take the time to listen to as many samples of said system as you can find. This is the reason I chose Analogue Solutions over Doepfer. Roughly, their cost is the same, and in my ears, the AS sounds fuller. It could also be that I am a drummer, and probably a little deaf! :)
AS systems are compatible with Doepfer and Analogue Systems modules.
Other suggestions: For a more "unique" sound when it comes to synthesis, try steering away from your standard Moog filter sound. Yeah, 24dB filters are great, I know, I have two! :) But your synth will be able to realize so much more with a few different filters. the MS20 clones are HUGE nowadays, and Doepfer is making vactrol filters that supposedly sound "creamier" than your standard filter. Mainly to do with an enclosed LED. When it comes down to controlling your analogue synth, you will definitely need a MIDI-CV controller. It's absolutely necessary for doing more than drones.
I've been reading your progress reports, and am still way back at page 7. I like your "elastic chest hair" idea!
My final suggestion - although digital effects are definitely on the less expensive side, especially when you want the most quantity for your currency - in the long run, you will be more pleased when you buy boutique analogue pieces. It guarantees a tailored sound, custom built to your preferences. That's a whopper of a discussion, though...
Thanks for your informative posts!
