Gordon's Progress Part 2
Posted: 4/5/2008 5:16:04 PM
[b]Ring Modulator[/b]
A small and slightly menacing metal box came in the post today, from Jake Rothman - see previous post. It's an active ring modulator with no internal oscillator, just two inputs. I have plenty of ways of providing two audio sources - the first being... two theremins, arranged so that the volume loops are close together so I can play them with my hips, whist reaching out to the pitch rods with my arms. (No interference problems as the Moog Etherwave and the Kees Enkelaar operate on different base frequencies.) Or I have an echo box that provides a ping-pong stereo delay from a mono source, and a pitch shifter that sends the original and the pitch shifted sounds to two outputs. So effects chains can become effects networks, with lots of interesting variations. At the moment I am feeding it the stereo output of my reverb box, on the faux reverse reverb setting and with a one second delay with lots of repeats chained on one of the channels.
As for the general range of sounds it produces, well, screaming, tortured, rending sheets of corroded, rusting steel is a start. In Round, PiL asked "How many of you have seen a factory? There's a boss held high, and the children die" but not before Throbbing Gristle announced, on the back of their Second Annual Report, "Music From The Death Factory." If I were to paint it, it would be black and red with the TG lightning bolt. Anarchic, aggressive and direct.
[img]http://mobilization.com/images/artists/tg/TG_Lightning_Bolt.gif[/img]
I am thinking of calling it The Annihilist, or Ann for short.
On Monday I'll be talking to Jake about a couple of things I previously suspected it might benefit from to increase its functionality - a wet/dry mix - at the moment very little of the unmodulated sound bleeds through; I'd like the option of having more of it, and a low pass filter; to take out some of the screechier aspects of the sound if I want.
Posted: 4/7/2008 10:48:05 AM
Or maybe I'll call it The Weirding Module.(*) Either way, I've had a fun weekend experimenting with it and starting to get some sort of control over it. Well, not exactly control. A feel for it, let's say.
Anyway, it's back in the post to Wales to add a wet/dry mix on both the inputs, and a low pass filter on the modulated output.
[img]http://www.hotshipment.com/images/rocket_man1.jpg[/img]
(*)“Raketemensch!” screams Säure, grabbing the helmet and unscrewing the horns off of it. Names by themselves may be empty, but the [i]act of naming…[/i]
Thomas Pynchon, Gravity's Rainbow, 1973.
Posted: 4/7/2008 11:21:27 AM
Alexander
For God's sakes, Gordon - I've said it before and I'll say it again. You need Bugbrand! (http://www.bugbrand.co.uk/pages/sounddevices.htm)
Posted: 4/7/2008 1:18:01 PM
ElectroMungo
I should ask Phil to send me two of his promised audio transformers and a hand full of germanium diodes... ring modulators are funny :-)
cheers
a
Posted: 4/7/2008 1:19:55 PM
fairplay
...I'd rather recommend (and am buidling myself ;o) a Doepfer (http://www.doepfer.de) (synth) effect as company to my theremin; you could do all this and much more...time and money is the limit, but that's the same as with the other effect-boxes...
...apropos effect: you did have a look at the Metasonix (http://www.metasonix.com) effects? I like the TM-6 especially...
Posted: 4/7/2008 1:32:18 PM
ElectroMungo
Chris, i think it´s comparable to the german proverb
"Mit Kanonen auf Spatzen schiessen" ... I think i won´t let rape my virgin little Kees-Theremin by a Döpfer Elephant :-)
Maybe a Danelectro-weasel is OK :-)
But the tube synths (your link) look great, i bet they are expensive as hell...
BTW i have a hommemade ringmodulator built in my Mungolator and it works fine together with my Theremin... This synthesizer costs about 100Euros (Material) and is homemmade except for the VL-1 (though labour cost is worth about 10.000Euros :-))
cheers a
Posted: 4/7/2008 1:39:29 PM
fairplay
...(I am at the airport heading for Bangkok and I have to run, so just short)...
...yes and no: this is - unfortunately - really becomming an elephant, but I bet if you one day find your way into my 'cellar' you will get infected too ;o)
...and: I am curious to see your Mungolator!
Posted: 4/7/2008 1:42:22 PM
ElectroMungo
i will bring my
Mungolator when i visit you in 3 month,
i´m curious about your Döpfer :-)
have a good flight my friend,
cheers
a
Posted: 4/7/2008 5:07:55 PM
Alexander, yes I do, eventually - because he's the only British boutique I've seen that does analogue [i]and[/i] digital. But first I need to work out what I want, and that means prototyping and learning what different things do, and how they interact. I'm still working on that bit...
Oh, and Alex - I now have the weaponry to meet you head on in the field of angry, noisy theremin combat! Consider yourself gauntleted.
Fairplay, no, Metasonix are new to me. Yup, I looked long and hard at Doepfer, and I do want a modular synth, but for a variety of reasons I'm planning to use an emulator - a Nord Modular G2 (http://www.clavia.se/products/nordmodular/index.htm), unless I can find an option I prefer more before I can afford to buy an NMG2. (Electromungo - even if it is using a hammer to crack a nut.)
Posted: 4/8/2008 4:33:01 AM
I found an interesting and amusing document last night, the Futurist manifesto, The Art of Noises (http://www.unknown.nu/futurism/noises.html), by Luigi Russolo, 1913.
Excerpt:
[i]Here are the [/i]6 families of noises[i] of the Futurist orchestra which we will soon set in motion mechanically:
1 Rumbles Roars Explosions Crashes Splashes Booms
2 Whistles Hisses Snorts
3 Whispers Murmurs Mumbles Grumbles Gurgles
4 Screeches Creaks Rumbles Buzzes Crackles Scrapes
5 Noises obtained by percussion on metal, wood, skin, stone, tarracotta, etc.
6 Voices of animals and men: Shouts Screams Groans Shrieks Howls Laughs Weezes Sobs[/i]
Yup, got most of that covered. :-)
