"Is it simply that the 'Hammond type' (ok, I know that there are others of this kind around) are newer technology and can do anything that the old style coils can do or is it current/voltage dependant so that on the older valve sets, the voltages and currents are greater so the coils have to be able to handle the bigger values? Thermal stability possibly? Bigger value induction in a smaller package?" - Roy
As a designer, one is usually looking to: A) Improve the performance B) Lower the cost C) Reduce the size.
With the possible exception of (A), using smaller ferrite coils achieves these primary objectives. Ferrites are more subject to larger changes in inductance due to temperature change, which is one reason they need to be carefully selected and matched to the other frequency determining components - but if this is done, I do not believe that large coils have any advantage.
The reason small coils are used is not just because "newer technology and can do anything that the old style coils can do" - it is because they result in a much lower cost theremin.
If we look at the component cost, and estimate the other costs for producing an EW for example - then compare this to the retail price - we are probably looking at something like a *6 multiplication factor..
If we add the cost of one large pitch coil (and to truly do the job the old way one needs large volume coil), this would probably clock in at about the cost of the whole circuit board.. Add to this the extra cost of the larger cabinet, extra costs for storage and postage of the larger theremins, and the EW would probably be selling at double its retail price - and I do not believe there would be any noticable improvement for this added expense.
To me (as a designer) the EQ coils are a pain in the backside - whatever form they take! Fortunately, I now think that eliminating them entirely is possible without reducing performance - a few little kinks to bend out, but with a few modifications to Lev's oscillator I believe this can be turned into a self-linearizing oscillator..
But in the meantime, I think the Hammond and Miller (which I have expierience with) coils do the job adequately - I have found no advantage from big air coils.
(ps - I dont see any reason why a tube theremin would not work with the smaller Hammond or Miller coils if the components are carefully chosen - But lets face it - Anyone going to the trouble of building a tube theremin isnt going to want small coils! - You cant build a tube theremin into an enclosure the size of an EW - So you may as well put big coils in - One is talking about a whole different philosophy and greater parts cost when one does anything with tubes)
