For my graduate robot control project, I'm having two robot arms controlling a Paia Theremax I just built. Yesterday I got everything set up in the lab and tuned, etc. The problem that I am facing is that I can only get about an octave in range with the range of motion of the robot arm. How can I increase the sensitivity?
The robot is all metal and is sitting on the same metal stand that the theremin is grounded to. As the end of the robot arm moves from about 18" (silent, low pitch) to nearly touching the antenna, I get about an octave range. Using my hand over the same range I can get about 4 octaves of pitch. Putting balls of stuff on the end like aluminium foil or static foam seemed to change the effect, but not in any dramatic way. What is the principle behind this?
My best theory is that since the metal cart and robot hardware are all acting as one plate of the capacitor, the moving robot arm isn't affecting the overal change in capacitance with the antenna. My body has a totally different charge and moving my arm has a greater relative affect on the capacitance, therefore I can get a wider range.
If my theory is correct, couldn't I connect a battery with one pole at the antenna and the other pole floating on the end of my robot arm and get a greater effect?
My project deadline is very rapidly approaching so I hope someone has an answer for me.
