"I wonder if breath pressure rather than volume of air past a constriction might be a better input?" - Dewster
I dont know - Its one of the things I hope to get some feedback on.. I started by using pressure sensors where there was no air flow, but it didnt feel right to me.. and also, the sensors were damn expensive and I worry that moisture etc will screw them up quite quickly.
What I have now is cheap and simple - I have a tiny electret capsule mounted on (what used to be) the exit hole of a nicorette inhalator, the way these inhalators are constructed is as two parts, the mouthpiece, and the exit shell - both ends have pointed inserts inside, so one places the nicotine capule inside the assembly, and when its closed, the pointed tubes pierce the film on either side of the nicotine capsule, and one can suck air through it -
I have arranged the electret so that the mouthpiece air is focussed on it - the exit hole is blocked and the wire to the electret goes through that.. Then I have drilled a hole on the bottom section of the mouthpiece - this is the air escape hole..
The electret is sensitive up to about 20kHz, but has a good sensitivity at about 16kHz (I originally looked at ultrasonic transducers, but could not find one at the right size - sure I could get these if I really needed them) - I amplify the noise, which (more by luck than judgement) has quite a lot of HF in it.. (my original idea was to construct a "dog whistle" type resonator, but I couldnt be bothered with all the work just to test the idea) .. So I HP filter frequencies above about 14kHz, rectify this, and get my CV..
I wanted as high an audio frequency produced as possible (within reason) because I didnt want external audio signals to be picked up and produce a CV.. But it seems that I have been perhaps a bit pedantic on this.. By biasing the output CV -Ve a bit, I can completely cut off any spurious output even with my crude cheap assembly..
I am quite pleased with the construction - the inhalators can be easily opened and the sensor cleaned (it sits behind a thin plastic film which I have roughed up to give more agitation when hit by the air flow, but its watertight and isolated) and the shape of the mouthpiece suits me well - I tried several different mouthpiece assembly ideas (bought a load of melodia and other spares off ebay) before I found an old nicorette inhalator from years ago when I was trying to give up smoking (I have now given up, and am addicted to E-Cigs ;-)
But as to what the players will think or want, I have no idea.. I can adjust the size of the exit hole by twisting the mouthpiece, and think this "feature" will probably be a good thing to keep.. but personally I like the feel of air flow far more than just using my mouth to control pressure in the mouthpiece - and I like a lot of air flow, as this seems to give better dynamic control - one can go really soft, and need to blow really hard to get maximum output.
"I'm definitely a fan of FM/iPD, especially of how inexpensive it is in terms of resources compared to resulting complexity...." - Explorer
Yeah, I had a lot of fun with FM/iPD back in the '80s - even had a Yamaha MSX "PC" with its FM sound engine.. Then got a some small Yamaha FM synths and a Casio CZ101 (in fact I still have that - keyboard removed and heavily modified as a MIDI module with knobs.. ;-)
But I find analogue far simpler - and for my new stuff, its all mainly analogue (particularly at the controller end) and interfacing the signals to MIDI or digital sound engines is not "my thing" - not at this time at least..... When I have it all running as I want with voltages I can measure (rather than watching decoded MIDI data on my analyser) and pitches I can hear, then I MIGHT start looking at MIDI or OSC..
However.... Analogue FM using topology similar to the Yamaha "operator" scheme is well within reach using HF VCOs, multipliers, samplers etc, and this is an area I have been exploring quite a lot..
But I cannot afford to be a full-time explorer anymore :-(
