"I'm still not convinced that the brain (or my brain) can interpret relative intensity levels faster or as fast as left/right motion to indicate pitch deviation. That doesn't mean that I disagree - I just won't know until I have tried both." - pitts8rh
A tangent: While setting up for that video I was watching the tuner on my PC monitor, and the small but obvious transport delay made it markedly less playable. I think any noticeable delay in performance feedback is absolutely deadly. Since the axis process filtering on the prototype is > 8th order @100Hz, there's at least 0.01s of inertial delay, but I believe inertial delay is less intrusive playing-wise than transport delay.
"Commercial tuner products use multiple display methods (adding a color axis, too), and it could be because different people simply respond differently, so there may be no entirely correct answer."
Barely along those (color) lines: the tuner previously had white LEDs for the "white keys" and blue LEDs for the "black keys". After a short period of time playing it this way I noticed my brain was paying much more attention to the patterns being traced out, that C major scale was so obvious it didn't need special marking, and that the different colors were actually interfering with recognition of the house pattern, and the two patterns rotated.
Also (color): Because I'm using different color LEDs I can't use a colored bezel in front of them to improve contrast, so was thinking of going with a smoked bezel, but that might hide the LED positions too much. I believe one could go with a single color for everything and not hurt readability / recognition. A black PWB background for them would definitely raise contrast, something I intend to do on the next go-round. Any thoughts on this?
The patterns are rather like stellar constellations, seeing an image in a bunch of dots.
"I hope that my earlier question regarding the possibility of reversing the rotation of the circular tuner display didn't give you the wrong idea. I hadn't even entertained the possibility that someone might want to actually view the display in reverse. I had a different reason for asking...
Earlier I had been considering the idea of putting the tuner display (detachable) out where it could be glanced at without distraction. When my prototype enclosure started to take shape it appeared that the pitch plate orientation was getting suspiciously close to being useful for viewing a reversed-rotating tuner reflected in the direction of the player's hand, provided the tuner could be rotated to face the pitch plate (mirror). It turns out that 1/8" acrylic mirror stock makes a fine conductive plate for a pitch antenna with some added benefits in that it is lightweight and it can also be heat-formed into simple or compound curves (gentle curves only to preserve the metalization) that may serve to benefit pitch contours at near-range. And it comes in attractive transparent colors too."
You rascal! :-) What an innovative idea! It puts more distance between the tuner and you, thus making it appear smaller, but allows you to keep you eye on the pitch antenna. If it weren't for interference I'd probably stick the tuner smack dab in the center of the pitch antenna, and this is one way to do it. So you're going to do a mild parabola to make it appear bigger?
I obviously haven't tried (nor even thought of!) your proposed arrangement, but I can say that a plate target isn't nearly as hard to "hit" pitch-wise as a rod. I do wander a bit now and then when sleepy, but my pitch hand & plate are sufficiently in my field of view that I can pay attention to it when needed. I've become accustomed to the tuner being about 1/2 meter from my face. The tuner is only ~0.25m from the pitch antenna and the pitch antenna is located somewhat behind it. But don't let me discourage you.
"Reversal of a stock 7-segment italic display would be a different matter, but that's a detail."
A parameter test and secondary 7-segment lookup table, ~20 lines of assembly. Mode knob is already there (often the determining factor!).
"The downside of this is that the pitch/mirror plate would need to be aimed more toward the main console than normal, making it less than optimum for its intended purpose, and there may be other disadvantages that won't become apparent until the theremin is actually up and running. A little bit of cylinder formed into the pitch plate/mirror would reduce the strict incidence/reflection angle positioning requirement (at the expense of introducing some degree of funhouse-mirror distortion), and may also be a good thing for close-field behavior. We'll see. If all else fails, a separate small mirror on a mic stand is still easier to deal with than a detachable wired tuner, at least in fixed settings where you could set it up and leave it."
It does seem like you could run into alignment issues. The plate doesn't need to be 100% perpendicular to your playing arm, though when you find yourself playing super close to it any angle could be a factor in how close you can comfortably get, particularly with vibrato going on and depending on your style there.
I need to get another volume side "shoe box" and try to cramming the pitch side in there as an experiment. The antenna could be a flattened U to retain surface area intrinsic C, but I'm mainly wondering if linearity would suffer much with that arrangement. Would be nice to use the same squarish box for both antennas. I believe it's much more about bulk surface area than the finer details of the geometry.
