A Tale Of Two Antenna Plates (& Woe)
Yesterday I printed out a full-sized version of the proposed antenna plate. Today I modified it a bit and printed it again:
First one is on the left, today's is on the right. Not a ton of difference, but significant. For today's I went with 2 top and bottom layers and 3 side layers, which seems better suited for the threads, and hopefully no one will ever see the backside of this thing (don't look! ;-). Jacked up the print speed to 75mm/s so the print only took ~6.5 hours. The threaded stud is now M12 x 2, which comes out kinda skanky when printed at low Z resolution, but likely still usable. The face went from 4mm thick to 5mm, which seems more rigid. The sides are flimsier with larger cutout holes and side thickness at 1.2mm. The box corner radii are larger, and because of that I think I will dispense with any significant back face to outer box chamfer. The countersunk screw hole geometry was messed up, and that got fixed. Next step is to design simple adapters for my current PVC coils and stick them in there with the AFEs. Production (god willing) will use printed coil forms. Moral: you can learn more than you can possibly imagine from a single print.
The ribbon cable & connectors & tool arrived yesterday, and I unfortunately had to send the latter two back to Amazon (I never return anything, particularly if I can fix it, so you know it was F'ed up). Connectors were fine, but the tool was so far out of parallel it basically destroyed anything I put in it:
Above is a view into the back of the tool. For it to work correctly one might be able to tolerate a degree or two, but this is an order of magnitude above and beyond working. I did get a bit of satisfaction by using two of the 16 pin connectors on my D-Lev cabling and crimping them with a C-clamp, but that was after almost ruining my soldered on cabling with this shitty tool, so I think we're even. Bad tools bad tools, whatcha gonna do... (is there anything worse?)
The good news is the main LCD / FPGA PWB Roger sent me + encoders are working 100% and looking quite sharp in their printed doghouse. So yay.
