"Then I see no express reason for trying to shave off a byte with running status." - Mr_DhamThanks! You're absolutely right, what's one byte in the larger scheme of things? "For want of a byte the kingdom was lost...""I may just try it and see if it works." - wingerrGood luck!
The one I just got has this part for U2,
www.sekorm.com
RS358A 1.1MHZ, Precision, Rail-to-Rail I/0 CMOS Operational Amplifier
The RS358A products offer low voltage operation
and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (1.1MHZ) and slew rate of 0.5V/us. The op-amps are unity gain stable and feature an ultra-low input bias current.
The RS35AA has lower offset, which is guaranteed
not upper than ±4.5mV at 25°C with Vs = 5V, VCM
Vs/2.
