FPGA Boards (aye, there's the rub)
Still poking around, looking for FPGA boards / replacements.
This is the FPGA board the first 20 kits used: https://smile.amazon.com/gp/product/B08BLFK7C2
You can still find them here and there, most want like $250USD which is like 10x what they cost a year ago. I found some for around $90, not sure if they're real or not.
I could probably use this: https://www.amazon.com/dp/B09FY2QBXX
But no 3.3V at the headers, and it looks like those headers can't utilize a single female socket per side due to the weird spacing between them. Odd configurator too.
This one is amazing: https://www.aliexpress.us/item/2251832762966437.html
Inexpensive, large FPGA, nice memory, sane pin breakout. But all three voltage regulators are of the switching variety (which might interfere with the fields?), the configurator seems non-standard (non-Altera), and only qty 15 are available.
This one is similar: https://www.aliexpress.us/item/2251832626667349.html
Same pros and cons as above, but the breakout headers are soldered to the wrong side, which makes it unusable. 190 pcs available though.
This one has the smaller D-Lev FPGA: https://www.aliexpress.us/item/2251832626066661.html
Pins on wrong side, and I don't think I could utilize the DRAM.
A more compact offering: https://www.aliexpress.us/item/3256803924610412.html
But the D-Lev sized FPGA can't use the DRAM.
This one is the closest I've found to the D-Lev board: https://www.aliexpress.us/item/3256804512902832.html
Pictures show pins both on the top and on the bottom, which is scary (what if they ship the wrong ones?). Plenty of inventory though, and I think I could buy it for less.
This one is very close too: https://www.ebay.com/itm/133952851480
But only qty 2 available.
There are a million of these: https://www.ebay.com/itm/123896865981
But pins are on the wrong side, and the square grouping could be problematic.
These are pretty and many offer it: https://www.ebay.com/itm/125040684205
A little pricey though, and it doesn't look like 3.3V is available at the headers.
Interesting Xilinx offering: https://www.aliexpress.us/item/3256802705341392.html
But again with the switching regulators.
I've been between two worlds on this issue for way too long. On one hand I'd like to make more of the original design, on the other I'd like to have more resources for development. But larger FPGAs draw more power, and the original design is right at the official USB limit. And supply chains aren't helping, though perhaps they're easing up a bit.
