The Varnished Truth
I performed the same experiment as André, but I measured free air resonance instead of inductance, hoping to detect any changes in self capacitance. Test subject was an unwitting 1.7mH coil that was accidentally wound with double coat magnet wire, so no loss if it got messed up. Varnish was "Rust-oleum Matte Clear Enamel" in a spray can. It contains acetone, liquefied petroleum gas, n-butyl acetate, dimethyl carbonate, petroleum distillates and aromatic hydrocarbons. I think I may opt for the "satin" version on my next coil. Drove one end of the coil with an FY6900 function generator, 3V sine wave. Sensed with a test lead placed a few inches away from the other end of the coil that went to my scope, with 256 sample averaging to reduce the noise. Coil was on top of two (count 'em) empty plastic boxes to minimize stray environmental capacitance.
Free air resonance:
- 2.554 MHz bare
- 2.557 MHz with varnish
- 2.546 MHz with heatshrink
- 2.546 MHz with varnish & heatshrink
These numbers are so close and so dependent on the setup that I'm reluctant to squint too hard to see any trends, or draw any conclusions. But I do think varnishing is a very likely a good move as it further immobilizes the turns, and so probably combats thermal expansion and therefore electrical drift.
I had a feeling something like this would crop up and render home-made coil dope a non-issue - often you just have to wait long enough for it to do so. Anyway, yet another experiment i should have performed years ago.
