Building Coils
Posted: 6/5/2012 12:19:49 PM
bcourson
I am ready to start building my coils.  I've done a few test runs using hard tubes and fishing line.  I built a coil machine out of a 1947 Evinrude 2 hp crank case powered by BMW wiper motor.  It works well.  My question is what exactly do the specs mean when they say the coils are 150 turns TAPPED at 50 turns? I see the schematic where L1, L4 and L5 "tapped" but what does this connection look like? Do you just bring a hole through the tubing and connect the tapping wire to the coil at 50 turns?
Posted: 6/6/2012 4:14:41 PM
Without having seeing the physical coil, I'd say after 50 turns you could just pull the coil wire itself through a hole and solder it to a lug, then continue turning the final 100.  I.e., no need to cut the coil wire or use another piece of wire for the tap.
Posted: 6/6/2012 5:58:07 PM
Chobbs
yes, "after 50 turns, poke a hole and pull the wire thru and connect it to a lug- then keep winding 100 more turns."   I'd  really recommend just using a hand crank, especially for winding the smaller osc coils. better control-  (maybe a converted sewing machine motor geared way down /with rheostat for speed control )
Posted: 6/7/2012 4:51:47 PM
mollydad
@Chobbs...Your coils are a thing of beauty...One of these days I want a tube theremin with your coils inside...
Posted: 6/7/2012 9:30:04 PM
Chobbs
Awe shucks- thanks!
Posted: 6/8/2012 12:07:22 AM
bcourson
Thanks for the great information.  Actually the old evinrude engine works great.  Here's my first coil.coil
Posted: 6/8/2012 12:12:49 AM
bcourson
Here's the evinrude winding machine.  Beware, it is not pretty and the faint of heart should divert their eyesdf
Posted: 6/8/2012 1:59:35 PM
No wonder you need an Evinrude to wind it, that thing's as big as a house! ;)
When you're not playing music with it, perhaps it can go ravage a planet somewhere.
Kronos: Ravager of Planets
Posted: 6/8/2012 7:09:38 PM
bcourson
Now that's funny.  Thanks for the laugh dewster
Posted: 6/10/2012 9:29:53 PM
mollydad
I see a remake of a Classic '50's sci fi movie in which the 50 foot woman plays her own scary music on a 50 foot tube theremin...Which will, of course take as much power to run as a small city....Dewster may have to help design some speakers big enough to handle this job..;-)
