There is another way to get the required inductances - a way I have been using quite a lot because of the difficulty in obtaining and stocking various values of adjustable inductors (and also extremely useful in tuning the Lev oscillator).
One can connect inductors in series, where the total inductance = L1+L2.. Or one can connect them in parallel, where the inductance = 1/((1/L1)+(1/L2)..) - As fixed inductors of differing values are more easily obtainable than variable ones, I use a 42IF106 IF transformer from Mouser, and take the required tappings to obtain the adjustable inductance I want - either in parallel or in series with a fixed inductor.
It should be noted that only IFTs like the 42IF106 which do not have a fitted capacitor, can be used in this way.
I have measured the following inductances across the 42IF106:
Pins 1 - 2 (103 turns) Up = 221.8uH Down = 517.7uH
Pins 2 - 3 (50 turns) Up = 43.6uH Down = 114.6uH
Pins 1 - 3 (153 turns) Up = 1.16mH Mid = 680uH Down = 489uH
Pins 4 - 6 (27 turns ?) Mid = 20uH Down = 29uH
Pins 1 - 6 with pins 3+4 connected, L across pins 1 and 6: Up = 703uH Down = 1.6mH
Up = Slug as high (near top of can) as it will go comfortably, Down = Slug to the bottom.
It should be noted that although it is possible to obtain the entire EW tuning range using pins 2 - 3, adjustment is quite course doing this - My preferred method is to put a 100u in parallel with pins 1 - 2, as this combination gives a comfortable adjustment range of about 69uH to 83uH, or using pins 1 - 3 gives 83uH to 92uH, so one could have "handbags" or links to select which winding one uses, and cover 69uH to 92uH.
One can mix and match series and parallel inductors - Rule of thumb is that if the tunable inductor is in parallel with a fixed inductor, the bigger the tunables inductance is, the less the adjustment range will be, and therefore if one wants fine adjustment, select the largest available combination from the 42IF106.
One can also use the 42IF106 configured as a 704uH - 1.6mH in series with the antenna coils, to give one some fine tuning on the antenna equalization.
One other nice thing about the 42IF106 is that its not a tiny component.. It fits on a 0.1" board if you angle it at 45 degrees.. It is also quite easy to dismantle and rewire - (I have calculated the core AL as about 29 when in mid position.. and about 21 with slug at top and about 48 with slug at bottom - but this is not absolutely consistant and I suspect measurement errors due to meter frequency shifting) one can quite easily remove turns to reduce the inductance.. This calculator helps!
