Hello TG, Welcome to TW!
Yeah, the apogee kit is cheap and simple - but its certainly not a "theremin" from any purist perspective.. its range (sensing distance) is tiny, and its a toy.. In terms of having a "step" function, I think you probably found the only "theremin" (other than MIDI theremins at the high end) with this function. IMO, the ONLY thing the theremin really has going for it is the fact that the player has complete control of the pitch - that this can be slid between notes, and that it is possible to add player controlled modulations both on pitch and volume..
Take the above away, step in tone increments (not even semitones, LOL ;-) and IMO you are far better off building a toy electronic "piano" using a 555 timer some switches and some variable resistors!
The Apogee kit will teach you nothing about theremins or electronics - all functions are embedded in a small PIC - its a bit like one of those musical greeting cards, and probably less musical than most of these! - But as a simple cheap project for amusement, go for it! .... But DONT think that it will give you ANY idea about what a "REAL" theremin is... IMO, its enough to put someone who doesnt understand this completely off theremins!
There is a long-standing hobbyist theremin web site where peaple are warned against me (although un-named - I am referred to as the "TW Devil") and one of the "identifying features" declared about me is that I recommend the SC/Jaycar theremin!
Well - I am going to do so again! ;-) ... I DO NOT regard these as "good" theremins (and have said so many times, and given full exposes of the technical reasons why I think they are not well designed) - but I do think they represent excellent value for money, are simple to construct and get running, and incorporate both pitch and volume at half the price of a little 3 transistor pitch-only board (which the webmaster of above site praises) .. IMO, the Jaycar theremin is the best value kit available, and the theremin one gets is usable IF the electronics is put into a bigger box so that pitch and volume antennas are further apart.. (and if the horrible speaker is removed and a line-out provided, and the audio amplifier is removed or the circuit modified as per the Enkelaar)
Also, there is a lot of builder / user generated data on modifications, and the kit can easily be converted to a Enkelaar theremin by more advanced builders.. In fact, some highly regarded (at least one ;-) theremins on sale for more than $500 started life as Jaycars, and got modified ..
But - It does not have a "step" mode.. A way to a step mode is to feed the audio (difference) frequency into a small processor like a PIC, and get this to produce the stepped audio output.. Even better, feed both high frequency oscillators into the MCU, and from this data derive the difference frequency and produce the semitone-quantised audio.
One other note - the simple Jaycar kit does not have a way to get the difference frequency before the VCA.. You would need to add a buffer and D-Flip flop (4013) to get a clean constant difference frequency..
My Element-14 Theremin group has loads of articles related to the Jaycar (including my H1 thereremin schematics that show how to interface it to digital, and schematics for the Enkelaar conversion) and other stuff ..
ps - (there is a Jaycar MIDI theremin kit - this will probably do what you want - if you have a MIDI instrument to 'drive' - but I have no expierience with it so cannot say.. It is real easy to produce a simple MIDI controlled tone generator using the simplest MCU)
This link:
http://www.thereminworld.com/Forums/T/29010/alternate-ways-to-generate-tone?Page=0
Is a good place to (I think) find some of the "extra" data required to modify a Jaycar .. It has links to my H1 theremin, and shows where one can get the required signals.. Ok, the H1 front end was based on the more elaborate EPE-2008 "Jaycar" theremin, but its similar enough that you can get a fair idea about what needs to be done.
