Sorry - this isnt a "players" perspective really - its technical, and could be regarded as at least a little OFF TOPIC.. But perhaps players would still be interested in reading / commenting on the idea of directional antennas...
"And if used to reduce the bulk antenna capacitance, a directional antenna could dramatically increase raw (%F/pF) sensitivity. You might be able to make a Theremin you could play with your hand a meter or more distant." - Dewster
Yes - with a fully implemented active directional antenna, you do get a dramatic improvement in raw sensitivity.
However, I have found that in order to drive the shield and simultaneously keep radiated signals from this shield to acceptable (legal) levels, one needs a secondary shield - It gets quite involved and quite expensive.. One needs to generate and control high voltage high frequency signals, and keep the phase of these under tight control, and these drive into a highly capacitive load.. There may be a simpler way to implement a fully active shielded antenna, but I have not yet found it.
So I cut back the design to reduce the complexity - ending up with a front end which was slightly less sensitive than a conventional 'open' antenna. One does not, I think, need sensing beyond about 70cm for theremins. The directional antenna does nothing to improve or reduce linearity - except when one plays at the edge of the field, where any left/right movement is converted to pitch change and is really bothersome - this is only a possible problem close to the antenna where the focus is narrowest.
It is possible to use 'low grade' shielding with conventional theremin topology, but this does (due to greatly increased antenna capacitance seen by the antenna) make conventional (antenna L) equalization a lot more difficult to achieve - so my experiments mainly went on the direct-to-voltage topology, where linearization was performed by analogue computation.
I do not see directional antennas, on their own, as a fix for linearization - perhaps the opposite.. I only really mentioned them in the context of sensing the 'background' capacitance without the players capacitance being "in field" (re Randy's question).. To be honest, I dont think this approach will solve anything.
But within the context of direct-to-voltage or AFE for a digital theremin, where one does post-antenna processing of the signal to 'bend' the response for linearity, I think directional antennas have huge advantage - the antenna response (whatever it is) will be much more predictable (there is far less influence from the environmental / background capacitances, so one has a nearly constant 'baseline) and one is starting with a nearly constant profile to which one can apply whatever post-antenna / front end linearization scheme one chooses..
Even the crudest passive (ground shielded) directional antenna, which adds almost nothing to cost, can work well when connected to a suitable front end - but does not work at all with conventional theremins employing series LC antenna equalization.. This kind of antenna has a massive fixed "background" capacitance which effectively replaces any fixed tank capacitance, but provides shielding.. For example, replacing the 180pF capacitor on the simple SC theremin, or better, replacing the capacitance required for a "tank" in a series LC oscillator - a big advantage of series LC being the higher antenna voltage.
One problem with forming capacitance between the grounded shield and the 'sensor' antenna is the problem of thermal stability - this is another reason for going the voltage route - one can sense the temperature and easily provide a correction voltage to compensate for this error.
I think Dewsters Capless FE, or some oscillator with a series LC tank connected directly to the antenna sensor , is probably the best form of topology for passive shielded directional antennas, but this topology must be followed by some form of computational linearization, and really also needs a thermal correction signal.. so its unlikely that one could directly take a variable oscillator signal from the Front end for heterodyning, or at least not unless its frequency (or the Reference frequency) was modified in a controlled manner to facilitate linearization / correction.. (This is not too difficult to do though, if one has a CV input to one of the oscillators driven from a voltage computed to correct the curve) .. But IMO, its better to just generate a linear voltage from the Front End, and use this voltage to drive voice modules (which can be complete heterodyning theremins) - this gives one the ability to scale the number of octaves and perform register switching and even have multiple voices operating simultaneously.
I have provided one thereminist with a early prototype of an uncompensated 'one stick' "theremin" (derivitive of my H1 without EQ coil [wrong.. looking at my notes I see this particular unit I did have EQ coil] ) using a passive directional antenna driving a conventional direct-to-antenna heterodyning front end, to one leading 'experimental' thereminist.. However the silence from this player makes me suspect its (as I predicted) not particularly useful, even for non-classical playing.. Active equalization will be needed to get a response better than what is available from a simple Jaycar / SC theremin.
IMO, another huge advantage for directional antennas is that other musicians can move about close to you (one less excuse for thereminists, LOL ;-), and provided they stay out of focus, they will not influence pitch - This was my first motivation for exploring the idea. I had a "working" prototype back in my earliest days when I was messing with Digital / PSoC, but at that time had no idea about the required range - my antennas had a 5V signal on them - easy to "shield" - but utterly useless for any real theremin application.. Moving up to the required real theremin voltages and ranges, I gave up on directional antennas for a while, and concentrated on matters which I only became aware of after exposure to real instruments and competent players.
