Hi Thierry,
I hope you are well during the pandemic.
Thank you for a nice simple design, and thanks for putting so much effort into answering everybody's questions ! This is much better than most internet blogs !
I could see the selected FETs were different to any I had in stock, but had no problem ordering the correct ones from ebay.
It would've been useful if your suggested PCB layout was a black & white image ready for photo etching, but It didn't take me long to reverse-engineer it.
With the reccommended components, the circuit was up and running in no time, with nice clean sine waves :-)
I have a general question - so maybe other readers could answer...
I'm using this circuit as a proximity detector - as opposed to a musical instrument.
My aerial is a 10cm flat plate, I want it to react nicely to a persons hand, in the (rough) range 30cm - 10cm.
I dont have the option to change the aerial plate design, as its part of a sculpture, but in theory I should be getting between 0.2pf and 1pf plate capacitance.
The output of the mixer is bufferred and driving a TTL divider chain, so it doesn't matter if the output is tens of kHz or just a few kHz, I just need a range of > 1 octave spread nicely over the distance.
At the moment, I'm only getting a noticable frequency variation if my hand is very very close to the antenna.
To improve the response,
* should I be raising, or lowering the frequency of the oscillators?
* is it worth tuning the fixed frequency oscillator to match the aerial / plate ? - for example by adding a trimmer cap and adjusting for max amplitude.
many thanks,
jonathan
