Volume loop latency in some presets.
I've noticed a bit of latency in the volume loop side when playing short staccatos with wide intervals. You can actually hear the glissando between notes, even though you're executing proper volume hand work. It's as if the volume loop looses it's sensitivity a bit when playing on presets where effects are involved, even when effect amount is turned down. The artifact is not as noticeable when playing on the Classic Theremin preset. (not to be confused with "theremin mode".) Also, when not playing multiple staccatos rapidly with jumps, the volume loop seems to work fine. Maybe too many things going on, too quickly for the processor to handle?
This is on rev 1.1.0 of the firmware.
Anyone else observe this?
