" In addition I think that neon bulbs, and similar solutions, would not increase the ESD resistance."
I am now even more puzzled - Do you have reason for this "feeling"? I agree that discharge tubes, when fitted correctly, only reduce the ESD EMF down from the initial thousands of volts to their breakdown voltage (usually 70V or more depending on part selected) and that this voltage is still able to cause damage if no other protective measures are taken..
But it is easy to add this extra protection if required, and often sufficient protection to deal with a 90V transient is built in to semiconductor parts if preceded with a few hundred ohms or (as in the case of some tough logic) has all the required components on-chip..
But as I see it, there is no possible way that adding a discharge tube in the right place wont improve reliability and increase ESD immunity - I would be most interested in hearing your reasoning on this matter..
Well, no - Im not really interested to be honest.. Its simply a nonsence statement with no possible theoretical or practical truth in it.. just as your statement about the 18pF capacitor was nonsence - its ok - its an easy mistake to make ;-) I spent 6 months working for an engineer who had a doctorate in electrostatics and ESD in particular, I may have been just as ignorant if I hadnt had this expierience! I have no wish to engage in further inane argument about this matter - I have said my piece, and you have not seen any failures - lets leave it at that with regard to the theremino boards.
I accept your position "Just to remind you, we are not a company, I'm not here to try to sell you anything, the only purpose for my posts, was to try to help. I am only a Theremin lover as you are..." and understand that in a hobbyist environment neglect for theoretical risks is common - I also understand how easy it is when one has a working prototype, to simply put this into production without going through the expensive verification stages almost all manufacturers must comply with..
(The following is a more general OT rant about some possible legal issues:)
I also accept that if we were all subjected to compliance (and in Europe, technically we all are - but it seems one can get away with non-compliance in the DIY sector and if one stays below the "radar") there would be far fewer theremin products on the market - As even through the self certification route, one needs at least one visit to a test lab (unless one owns the required equipment and facilities) to verify things such as EMC and ESD before one can legally sell an electronic product... In fact, even to have 16 theremins on display for the public to use for one week, I was forced to have each unit checked for safety, and basic EMC and ESD tests were performed by the customers engineer, before use of the equipment was permitted.
I think different EU Nations enforce compliance to differing degrees - It seems to me that the UK is far tougher on its manufacturers (or at least forces compliance with the directives) than some other EU nations are on their manufacturers - I have seem stuff from EU nations having a CE mark but failing on almost every important directive (and when I find outrageous ones, I report them ;-).
(my biggest problem with compliance is the RoHS directive - I simply cannot use the awful lead-free solder, so will be forced to have boards built by contractors - I will however keep all active components socketed, so I can fit these myself - but if I ever go into production the first units I produce will be compliant on everything except RoHS - but in theory my selling any newly built electronic equipment which does not comply with RoHS is an offence that could result in a hefty fine. - The same applies to product which has not undergone EMC / ESD testing - but its easier to detect lead than it is to detect lack of testing.)
AFAICS there is no mandatory ESD immunity compliance requirement on general electronic products anywhere in the world except the EU (I am sure though that other countries will have adopted and enforce similar standards) - So Moog for example probably do not face possible penalty. Standards are certainly enforced on products for critical applications, or where UL certification is required.
To be honest, I dont know what the EU rules are on importing non-compliant products from other nations - I understood that all products imported required CE certification, and if this is true then the sale of some theremins in Europe is technically illegal.
Personally I applaud the EU position. Manufacturers should be forced to comply with good practice if they wish to sell into Europe IMO! - For all its faults, I strongly hope that our stupid government and the masses of brainwashed morons in this country dont manage to pull the UK out of the EU!
"The European Union’s EMC Directive mandates ESD immunity testing for virtually all electrical and/or electronic products as a condition for obtaining the CE Mark before shipping to a member state of the European Union. "
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_esd_006
http://snebulos.mit.edu/projects/reference/NASA-Generic/ANSI-ESD-S20-20.pdf
http://cds.linear.com/docs/en/quality/esdprotection.pdf
