Now, Mr. Frenkel has a free minute and he'll tell you exactly what happens:
When you connect the pitch arm comprising 4 inductors and a small variable capacitor to your Epro, you add a series resonant circuit to the oscillator's parallel resonant circuit which helps for linearization. The resulting resonant frequency is either above or below the individual resonant frequencies since the equation is biquadratic and has theoretically 4, but in practice 2 real solutions.
By having the antenna circuit's resonant frequency slightly below the oscillator's free run frequency, the combined system should automatically jump onto the upper solution (since it is closer) and everything will be fine.
If both resonant frequencies are too close, either because the oscillator's free run frequency is too low or the antenna circuit's resonant frequency is too high, the whole system will tend to jump on the lower solution, which is much more far away from the fixed oscillator's frequency, giving a very high pitch. By touching the antenna, you pull the antenna circuit's resonant frequency temporarily strongly downwards, which helps the system to jump up onto the "correct" resonance. It will then often remain there, as long as the oscillators run. That is neither a damage, nor a real problem. This effect can appear thanks to changes in the environment (temperature, humidity, etc.) or due to component aging which makes the resonant frequencies vary slightly.
If this phenomenon starts being annoying, it can be cured by either raising the variable pitch oscillator's free run frequency which is very difficult in the Epro, you'd have to use a frequency counter and fiddle with some of the jumpers and one variable capacitor on the pitch board. But that's not the usual way.
Or, and that's what we will do, you can easily lower slightly the resonant frequency of the pitch arm. It has for that purpose a small hole on its bottom side through which you can tune a very small variable capacitor. You will need a torch to find the capacitor's slot, it is much smaller than the hole. And you'll need a very small screw driver or preferably a plastic RF tuning tool with a ceramic point made for these small slots. Now you should try to adjust the pitch arm's resonant frequency with that by turning the variable capacitor in very, very small steps until the startup frequency of the whole system will be stable and not longer jump. But you shouldn't go too far because if you lower the pitch arm's resonant frequency too much, the linearity will not longer be optimal (the tone spacing in the highest octave will shrink) and you risk to come out of the tuning range of the pitch knob.
Don't hesitate to post your experience back here and/or to ask further questions.
