Hi, I just finished building a Theremin using Moog's etherwave schematics. Every module seem to work correctly. I then started to adjust my oscillators to match my antenna's resonant frequency. I did the volume oscillator first. The problem is that I am not able to find a good tuning that would give a decent range.
First, I didn't used exactly the same component. I wasn't able to find the variable coils described in Moog's article. Instead of a 47uH variable coil with a 33uH fix inductance I used a 11.8uH variable coil with a fix inductance of 68uH. I know that my variable coil range is now narrower but I thought I would be able to fix it by adjusting the capacitors used in the tank. I also changed the LM13600 for a LM13700 but it is not important I'm pretty sure ;).
The thing is, I changed the 6800pF for other values and looked at the frequency of the oscillators as well as moving the variable coil from one end to another. I found that if I placed a 1000pF instead, and adjusted the coil or the potentiometer associated with the volume (P1), I was able to invert the direction of the antenna. In other words, at, example, 80% of the coil, the antenna reacts normally (less volume when the hand is closer) (but sadly with a short range of about half a foot) and then at 81%, I abruptly hear the sound going down and the direction of the antenna is now reversed (more volume when the hand is closer).
Additional information : All the above tests are made with an oscilloscope reading the net L7-C12-R17... The frequency at the tipping point is between 694kHz and 730kHz depending on the potentiometer. When I unplug my oscilloscope from the net, the sound disappear and I can't here anything.
My questions are : Is this a normal behavior or can there be an error elsewhere?
Can I find the perfect tuning by simply changing the capacitors for different values?
Is there a way to measure and/or calculate the perfect frequency for my setup?
P.S. I have access to a wide variety of debugging tools including oscilloscope, capacimeter, ohmmeter, etc. (and also my earphones :D) Also, I would prefer not having to change the inductance/coils.
