Hello,
I've read some other posts regarding this topic regarding pitch antennas, and tried some of the suggestions, such as placing inductors inside a plastic bag, moving the antenna away from most objects, etc. Nothing worked.
I was wondering if there is anything wrong with these inductors we are using: http://www.farnell.com/datasheets/24558.pdf (part no. B82722A2102N001).
Also, when I touch the antenna, the frequency shifts very slightly, but other than that it does nothing. Some other users had this happen but a lot of the suggestions we tried also didn't work. We are using a 3/8'' copper tube, 50 cm in length.
The project we based the oscillators on is: http://www.cs.nmsu.edu/~rth/EMTheremin.pdf
Right now we just want to see the pitch antenna respond, so we have two identical working oscillators connected to the detector part of the schematic, and we want to see the antenna responding to hand movements. Below is what we have so far.
Please let me know if there's anything we can try, or what sort of tests we can make. The main thing I have in mind is taht we do not have a variable inductor (L5), but we have tried many different values and the end-result is the same, so we're very skeptical that this is the problem.
Thanks!!
