Hi,
I am currently encountering a couple problems concerning my etherwave theremin. I am building it according to the schematic drawing in this pdf http://www.suonoelettronico.com/downloads/HotRodEtherwav.pdf
One of the problems is located in the volume circuit witch behaves as follows: volume antenna circuit oscillating at 441 kHz, VO is oscillation around 480-490kHz(should be 450kHz), these produce less than -0,1 V at R14. Any idea why?
Also, when introducing an injected, adjustable, voltage (via a potentiometer) we where able to control the volume (with the volume circuit disconnected). We also tested with another totally functioning Volume circuit producing -3V and got no sound or volume control. Why do the injected voltage work but not the functioning volume circuit?
