Thank you all for your kind answers and advice!
dewster: I see what you mean by the poor inductor industry in relation to Theremin builders. Technology shifts with no mercy hehe, but best of all is that there are always diy methods of recreating practically anything with enough wit and perseverance. As I started to mess with inductors and testing the ones I've scored from old equipment, I tried to build my own, variable and fixed, using a bit of paper rolled around screws, old ferrite cores and what not, loose enough to be able to adjust the inductance. The very first intent actually worked, I used an old radio antenna coil ferrite bar (around 6mm in diameter), broke it in 3 sections of around 2.5cm long and on top of a bit of paper wound a couple of layers of some magnet wire from an old transformer. The wire is 0.01", or around 0.25mm in diameter (measured with digital caliper the outside diameter). I was after the original 100uH and 68uH variable coils. By measuring the inductance, I had to unwind all of the second layer and with several cuts and measures got it to 100uH. They worked quite well in the oscillator giving a clean and strong sine on the scope. The drawback is the coarse value shift when moving the ferrite inside of the coil with the lack of an adjustment screw - but oh well, it gave the starting incentive to keep going!
It definitely makes sense to use the most appropriate and convenient parts for the application. I will look into getting the best possible low TCO components.
About hand wound air core coils, what should be the optimal limits of their DC resistance? As I understand, the lower the resistance, the higher the Q? What would be a reasonable maximum of resistance those 47u and 22u fixed coils should have to stay within the operating range of the oscillators with the surrounding components values as suggested without having to adjust them?
Thierry: I appreciate your comments. I understand how there are different approaches to implementation of technologies and how it all comes together in a functioning device. So many factors, engineering and soul-wise, in the end it is all art in one form of another. Its incredible what it is possible to make using combinations of both, sometimes going out of rules, even if messing things up, one ends up learning from the process and maybe even innovating something in the meanwhile. I myself often cling on "reinventing the wheel" having one in front of me ready to use hehe.
Once more, appreciate all the responses, as well as for indirect, yet very useful help and ideas I have gotten from yours and others older posts in the forums - some very concise and tested/experimented information, always useful to know from first hand experienced people.
Best regards,
Konstantin
