Theremin Volume Control - What's Ideal?
Valery the lady after Christmas is a great idea, I want to send you many parts as your success is my success.
Everyone the photo below is my pulse width modulation theremin volume control. Now that I can do multi layer printed circuit boards someday I will reduce the size of the 3” x 8” board. Right now I have about 30 of these longer boards waiting for that adventurous University student to experiment with. This same board can also be the Pitch side for sound with a variation in the components.
The standard passive theremin volume can use over 2 kHz in variation or off tuning to quiet the sound. My PWM approach can do the same thing in 200 Hz that can be spread out over a 24” volume-shading window using a 4” antenna. Use the 4” high voltage wire, I showed earlier in this thread, placed in the loop and the volume can have a softer response on the outside edge of the loop, then aggressive at inside edge near the wood box. The parts are minimum and the Vactrol can be seen.
I hope I am not falling into that pit of moving away from practical and making something so complicated it gives me an excuse for not succeeding.
“Simple can be harder than complex: You have to work hard to get your thinking clean to make it simple. But it’s worth it in the end because once you get there, you can move mountains.”
― Steve Jobs
"But that's a side effect, no? Ideally the oscillator frequency wouldn't be influenced by the antenna LC, correct?" - dewster
yes, and divider of C14-C15 helps to neutralize this influence. But there is nothing wrong in this effect, the circuit is operable in any case.
August 28, 2016 - Happy Birthday again Lev Sergeyevich Termen.
Here is a sound sample of my theremin volume method using Pulse Width Modulation. I find it to be more precise than the passive approach. It gives good control throughout a 40 cm volume window with the quiet range spread out for easy soft control. It is distortion and noise free at any level.
Ideal Volume Control .wav
It is best played in Audacity so you have a visual. I am using a radio for the audio.
The right hand controls the pitch, Yes
Left hand controls the loudness or amplitude of the acoustic signal.
Without pedal
Hello Valery,
I confuse myself all the time. My sound demonstrates complete use of the 40 cm dynamic range with a staccato at the whisper parts.
The circuit-board up above, without distortion all of the range.
Ideal Volume Control-3 .wav 6 meg
