Oscillator phenomenon going in and out of oscillation
Posted: 10/26/2017 9:33:17 AM
vivitern
An oscillator using a ceramic resonator is going in and out of oscillation.
I have an oscillator circuit with a peculiar phenomonon. The oscillator does work (mostly).
BFO oscillator
The “crystal” I am using is a Kynix resonator KY163-AWCR-10.00RS.
This oscilloscope photograph shows the output voltage (Vout) and gate voltage. Channel 1 (yellow) is Vout. Channel 2 (blue) is gate voltage (to ground).
enter image description here
After a few seconds (approx 10 seconds), the output slowly fades to zero volts AC (DC level maintained at near 9 volts). The gate voltage (AC) also goes away (DC level maintained at 0 volts).
The “fade away” takes about 5 seconds, then stays at “no oscillation” for about 10 seconds. Then, slowly the oscillation begins and grows back to the original magnitude in about 6 seconds.
I monitor the the volts across the 100 ohm resistor (R2). When oscillating properly, the volts across the 100 ohm resistor is about 0.7 volts ( 7 mA). When the oscilation begins to die out, the volts across the 100 ohm resistor drops slowly down to zero volts (Id=0). As if the JFET were cutoff, yet I see zero volts on the gate (gate to source) (cutoff voltage is -2v to -6v) (Idss = 10mA). So how could drain current be zero with gate volts at zero (not cutoff).
The schematic shows a 2N5486, but I am using a HEP802 ( I know it's an antique ). My purpose here was to make a BFO (Beat Frequency Oscillator) for antique radios that I restore. So Morse code can be heard on old radios. HEP802 equivelant to 2N5486.
If I touch the case of the ceramic resonator with my finger, I can influence the timing of the fade in and fade out phenomonom. But doesn't effect the frequency of oscillation.
The circuit does stabilize in the oscillating mode.
Given the timing of the fade in and fade out of the oscillator, it would seem to be a thermal phenomonom. I recognize that a substantial current is flowing through the resonator (series resonant).
Is there a thermal function of ceramic resonators not specified? Any thoughts on this phenomonom ?
How does Id go to zero without the gate voltage being at cutoff?
EDIT 1/9/2016 : per Andy Aka suggestion, R1 was reduced from 1M ohm. At R1=270K, the fading in and out of oscillation stopped, with the oscillator running with same output amplitude.
Remaining puzzle is still How does Id go to zero without the gate voltage being at cutoff? Id=0 Vgs=0 when oscillator previously failed to oscillate. Shown in second photograph above, with both oscilloscope channels on DC coupling.
Posted: 7/13/2019 3:56:14 AM
GeneralTiger
Allicdata se puede encontrar similar: https://www.allicdata.com/
Posted: 8/1/2019 6:08:01 AM
GeneralTiger4
The oscillator is simply a frequency source and is typically used in phase-locked loops. In detail, it is a device that can convert DC power into AC power without external signal excitation. Generally divided into positive feedback and negative resistance. The so-called "oscillation" implies the communication, and the oscillator contains a process and function that never oscillates to oscillate. Such a device can be converted from DC power to AC power, and such a device can be called an "oscillator."
Posted: 9/29/2019 6:55:10 AM
GeneralTiger4
Oscillator Model:ASFL1-25.000MHZ-EC-T
