I just got a used Moog Theremini, and I'm having a problem calibrating it. I could get it to calibrate correctly a few times before this, but now it's having a problem.
Even though I place my hand at my chest when prompted to calibrate the farthest note, when I try to play, the theremini registers the lowest note at about halfway in between my body and the antenna (about 7-8 inches from the antenna). Any closer to my body and it mutes.
I tried changing the "Mute when pitch hand is far away" setting, but that actually makes the pitch go up the farther I move my hand back from that halfway point. I also tried changing the scale range, but that only changes the range within the same space.
Thank you for your help!
