To raise the maximum pitch of an Etherwave Standard with ESPE01, do I raise or lower the pitch antenna wire? What is the maximum frequency I can get? Thanks.
Pitch wire
Posted: 5/31/2018 10:12:41 PM
If you want to increase the pitch range of an existing theremin, you would need a slightly shorter and thicker antenna. The length and thickness should be chosen so that the static antenna capacitance remains approximately the same. Otherwise the calibration could become difficult.
