"What are you using for coil dope?" -Dewster
I'm using a homemade brew of white polystyrene foam blocks broken up and melted in toluene. I think it's essentially the same as the q-dope that you buy. It dries fast and hard, although I think MEK as a solvent might make it dry even more quickly.
"Are the insulating tubes on the resistors and such stripped wire insulation?"
Yes, but I could have chosen better for heat tolerance. Both types that I used tend to melt. For my later mods since these pictures were taken I've just used colored heat shrink.
The red/black striped wire was made by twisting white wire held in a vise with a drill, laying straight stripes down opposite sides using marker pens, then letting it unwind to form the spiral. I wish I had figured out this trick back when I was hunting for different color-coded wires for my complex CNC panel wiring job.
