"Dielectric losses dominate at the hot (high voltage swing, high-Z) ends of resonators, while conductor losses dominate at the low-Z drive end, and you sometimes see both types of losses referred to one end of the schematic model (for example, conductor loss at the drive end modeled as a high resistance value at the high-Z end)." - pitts8rh
Ah, that seems much like how coil Q can be lump modeled as low R in series or high R in parallel.
Roger:
1. What do you think of my use of PVC (relative permittivity ~3, or so I have read) as a coil former? I could get thinner wall tubing (and may for structural reasons) but I believe that's in an area of diminishing returns? Paper is around 2, but add some phenolic and it could easily go much higher? It's tough to get below 3, and I'm uncertain as to the value of that as a goal.
2. What are you target inductances for your Pro? When the antennas are similar in area, I recommend a 1:2 ratio (pitch:volume), and maybe don't go below 0.5mH. I'm running 1mH:2mH for P1 & P3, 4mH:8mH for P2 (coils I has lying around). It seems, to some extent, that smaller inductors tend to have higher voltage swing, and the oscillator with the lower voltage swing tends to be the one that experiences interference from the other - if that is the case then you want the pitch axis to have the smaller inductor.
3. Assuming it could be worked out physically, do you think it might be possible for you to use an air core in the pitch arm of your Pro? Or do you think the concentration of the ferrite is essential to the C-field shape for your style of playing (so that you aren't "playing to the arm" - an active horizontal support could be a compromise in this regard)?
4. Do you understand what's going on with the insulator over the ferrite? Is it mainly to reduce capacitance? I can't say I've ever read anything about it, but I abandoned ferrite fairly early in my research.
