Burns B3 Deluxe only producing static/hissing
Posted: 2/17/2023 1:04:50 AM
letsallgooutside
Using a grounded amp solved the problem! I will get a more appropriate power supply when I can find one. Thanks for the help, all.
Posted: 2/17/2023 6:44:09 AM
Martel
The reason seems to have been identified. Your current adapter does not fit. You need a transformer power supply (power adapter) with an output of at least 14 volts.
(although 12 volts may be enough. But this is just an assumption)
I have been planning for a long time (but have not yet succeeded) to try to power the theremin from a good switching power supply. From the adapter to the Shure radio microphone (12 volts). To check if the statement that switching power supplies for theremins is absolutely unacceptable? Or high-quality adapters will not give high-frequency interference?
(I don't think I've gone too far off topic.)
Posted: 2/17/2023 12:51:24 PM
"Using a grounded amp solved the problem! I will get a more appropriate power supply when I can find one. Thanks for the help, all."  - letsallgooutside
Yay!  Good grounding is absolutely essential to proper Theremin operation.
What do I win?
Posted: 2/17/2023 4:04:55 PM
Martel
And what if he is not in the apartment? )
