Newbie needs power
Posted: 10/9/2024 6:53:42 PM
spacefaerie
Hey, all. I'm new to this group & new to theremins, though I've found them fascinating forEVER.
A friend is loaning me a Moog Etherwave that her gf's Dad built from a kit years ago, but it's missing the power cable. It's the 5-pin DIN connector, and from what I'm seeing online, they're pretty hard to come by? Someone suggested to DIY it & solder a connector to a new power supply, but... I need more instructions. I'd love some leads on vendors that might have it, or a how-to on putting something together that will work (and like, not burn up my friends' instrument!). Any leads would be appreciated!! (I'm in US.)
Liam
Posted: 10/10/2024 10:20:31 AM
"A friend is loaning me a Moog Etherwave that her gf's Dad built from a kit years ago, but it's missing the power cable. It's the 5-pin DIN connector, and from what I'm seeing online, they're pretty hard to come by? Someone suggested to DIY it & solder a connector to a new power supply, but... I need more instructions. I'd love some leads on vendors that might have it, or a how-to on putting something together that will work (and like, not burn up my friends' instrument!). Any leads would be appreciated!! (I'm in US.)"  - spacefaerie
A quick look on the web shows they're all out of stock, even Zzounds which the Moog web site points you to.
The supply itself is pretty simple - I'm showing the regulators and associated passives here too, which are internal to the Etherwave and not the supply, which is just a transformer:
If I were doing this I'd buy a raw 115VAC / 14VAC transformer and stick it in a plastic project box.  That would allow me to connect the AC ground to pins 2 & 3 of the DIN, thus grounding the Etherwave (proper grounding is critical to Theremins) - I might include a ground lift switch to eliminate ground loops if the audio path is grounded.  I'd maybe include an on/off switch, and perhaps an LED indicator.  I would use an IEC socket for the AC input so I could pick from the variety of unused computer type cords one tends to collect.
Here is a transformer at Mouser that would probably work: https://mou.sr/4dChZ8p  More amperage than 200mA is OK, less isn't.
Posted: 10/10/2024 12:54:19 PM
gerd
Maybe this one with an other connector:
https://www.ebay.com/itm/164969698327?_skw=wa-1410-2+ac%2Fac&itmmeta=01J9V7PCEE8TWZJ45G3982VJKW&hash=item2668f5d417:g:-WgAAOSwfMZg9vZe&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKmuD5L6pgJqz6Uo3U%2B9sxwPTYNGY6HQRm75WZaJHs2AP8ieHhcX2el19d1Tgqdw%2FO%2B72B0bIo4QxGKNe4RGp2A2EHX0tCT0kPDD4qTZhrvKieqLrK0Oozvk91Ea7cae89f31CAzXoAE2fglK9Gq1UzVupB4NLxM%2FWiUvkaBWbfO%2FHktD6lQBM0tq%2FDNO4hk%2FsqWUEguvfRCP4HB8SMUpBYoN7fNLLEkqKMlZCA%2FlWzm2sDQSQEXqWQlL5BR5%2Bjv9%2B0%3D%7Ctkp%3ABk9SR6rH2efOZA
Posted: 10/16/2024 5:31:08 PM
spacefaerie
Excellent info, thank you both! Wish me luck....
