Hi there everyone
I have a pretty basic question about making the antenna of the Junior Theremin work at distance from the main pcb.
i should say I first tried adding some coax cable and sticking the antenna wire on the end but the whole cable became active and I just want the antenna to work away from the pcb.
I thought if I ran a ribbon cable from the 555 to a metre away along with a wire for the 1M resistor this would work but unless my soldering is too bad (which is possible!) it doesn't react (yet the board itself does if somewhat randomly not connected to any hand actions)....
Am I missing something really basic please? Theschematic for the Junior theremin is here http://www.madlab.org/schematics/JuniorTheremin.pdf and some bad images of what i did (I'm a novice at electronics)....
best wishes D
