Announcing...
The world has been waiting for them, and here they are...
[i]two completely new electromechanical theremin effects[/i].
They said it couldn't be done, but they were wrong...
...I give you the...
[b]Frothatrill[/b] [i]and[/i] [b]Twangulator[/b].
Well, OK, not completely new, the frothatrill is the coffee frother trill device, refined by adding a second wire propellor blade on the other side of the whisk to the first one. This doubles the speed. The slower speed is still available by folding back one wire.
But it's an interesting point, isn't it, that in live performance you have not only analogue and digital effects, but also electro-mechanical ones by introducing conductive objects other than the hands into the pitch and volume fields.
And they have the advantage that they do not mess with the output signal - this is still a totally pure theremin voice, unlike a stomp-box effect.
News flash - I recall omhoge lamenting here (http://www.thereminworld.com/forum.asp?cmd=p&T=1648&F=780) on the poor forgotten volume loop, and here a nod in his direction for setting me thinking - with a bit of adjustment to the volume field and, holding the frothatrill at the very end, letting the propellors (or propellor, I prefer the slower speed for this) dip into the centre of the volume loop, gives a neat tremolo.
And thinking about that led to the Twangulator.
Ever trapped one end of a school ruler against the desk and twanged the other end. Thrubbadubbadubbadubbadubdubdub?
50 cm (18") steel ruler lashed by the last 8 cm (3") to the top of a dining chair so the free end sticks under the volume loop, just below the active field so it doesn't get in the way when not in use. To use it twang the end or tap the middle rhythmically. The end bounces in and out of the active field, modulating the volume. Hence "the twangulator." The hand can be moved closer of further away whilst tapping to vary the overall volume. Attach a large fridge magnet to it to alter the speed.
What fun!
