"Yes it does, the brass shim where the antenna locks into is machined on both sides to accomplish just this." - hudri
Thanks for that info! So you should be able to just swap the plates and oscillator boards to change the handedness? This doesn't swap the positions of the front panel pots though, I wonder if the lefty instruments from the factory do that?
"Moog got some things quite right with attention to detail. And messed up with some blatant oversights at the same time."
Other than the antenna connectivity fiasco, and the stand issues, the physical design seems OK. IMO they retained too much of the opaque / complex / changing too many parameters at once Theremini calibration, and released buggy beta software. Something this digital could really use a $1 LCD display, and proper encoders rather than pots pressed into service as such. Perhaps it should have been 100% analog, with no "Modern" mode - an updated & improved EPro, but in the Cvox cabinet.
