on my behrenger 1206 pfxpro
by the aux 1 send on each chaneel is a "pre" button - press it and then press the mute button by the volume fader and the signal will not go to the main out but just to the aux outs depending on how you have them set.
now all you would need is a mixer with the capability of routing the aux channel and the main channel to a seperate bus that can be patched to the headphone out.
my mixer doesn't have that. if you hear the muted channel through the headphones, the uax also goes out the mains.
i think that a spot monitor or seperate amplifier would be easier and cheaper.
