The case is finished, the urethane varnish just has to cure hard.
To connect the antennae, I found 1/2 inch ring terminals at Kragen Auto Parts and reamed them out to 9/16 inch with a round file. Looks good.
The open end of the pitch antenna seemed unaesthetic, but I couldn't find a satisfactory matching plug or cap. Finally I rounded the end of a 3/8 inch dowel (same diameter as the antenna), stained and finished it to match the case, and cut off a small piece (about 1/2 inch). I put a bit of hot glue into the end of the antenna, pushed a bit of 1/4 inch dowel in flush with the metal, and added a dab of super glue to hold the finished bit of 3/8 inch dowel. Doesn't look bad.
I cleaned off the work bench (well, enough of it) and tomorrow will set up for electronic assembly.
