I added two pipes covered with rubber from bicycle tube (prevents from sliding) and two bolts + piece of metal to set height and width of stand.
theremax cabinet
http://www.paia.com/ProdArticles/Images/therwood.gif http://www.paia.com/ProdArticles/Images/thermetl.gif
My theremax is entirely DIY (cabinet, antennas, pcb, panel etc). Remember to have metal plate under pcb, whole bottom of theremax should be covered (I have 1mm thick aluminium and 3mm plywood - probably thats why my theremin doesn't interact with stand).
Volume antenna is 10mm diameter 1mm thick aluminium pipe bent bare hands on this: [img]http://i1123.photobucket.com/albums/l557/Arsimantur/th_100_3602.jpg[/img]
Pitch antenna is from broken lamp 12mm dia 2mm thick, probably steel, screwed into thicker piece of pipe, maybe part of faucet I found somewhere. Remember to polish aluminium pipes with polishing paste and felt to give it shiny look. It's good to have two antennas which are disconnected easily for transport. Look for shops selling aluminium in your area to get aluminum pipes and sheets.
Some photos of my theremax and antennas are here: http://s1123.photobucket.com/albums/l557/Arsimantur/
theremax cabinet
